16“ Vorderrad
Jan::Team-Bendom
Gibt's nicht
Hast recht...Alpina verkauft keine einzelnen Ringe [emoji19] bestätigt über drei Händler.
Alpina bietet an die Nabe hinzuschicken, so dass die den Umbau machen. [emoji28] Die Wartezeit ist sicher riesig und die Kosten auch.
Bleibt also wohl nur verkaufen und neu kaufen
Gesendet von iPhone mit Tapatalk
I am sorry I can't write Germany but if needed I can supply 16" rims + spokes or you can send your hub to me and I will build it for you.
Black 16" rim + silver spokes = 215€
If you send me your hub I can build you tubeless wheel on your hub for 285€
It is VMX rim. Same that was used by fastest UK supermoto driver Lewis Cornish on his Husqvarna 450 on his battle against World #4 rider Simon Vilhelmsen on Asian Championship on season 2017 and on his French Championship TM bike on season 2018.
With 16" front wheel there is very little clearance between brake caliper and rim. That is why we also have developed 1 of the slimmest brake calipers to work with 16" front wheel. Picture is of KTM SX 250 with VMX 16" front wheel, 310mm disc and caliper + axial to radial adapter.
Am 16.1.2018 um 21:07 schrieb KevinCR:
Ja, mit M50 & 16“ geht's einigermaßen ...
Jan, frag mal beim Marc-Reiner an wegen 16“-Felge, vielleicht hat er was.
Am M50 Sattel hinten nen Bissel was Abfräsen an der Schrägen kante oben circa 2mm und Schwups / Passt ;)
Edited by Husawusa
On 1/20/2018 at 11:35 Ben wrote:
Wow, that looks good!
And it works pretty damn well too. One of the best features on VMX is clearance on all directions. We have all had the issue with calipers which are just too wide. This issue has been thought about too.
Edited by zap
spelling error
