Ben Posted October 15, 2013 Report Share Posted October 15, 2013 Kannst du mit Backofenreiniger machen. Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted October 15, 2013 Report Share Posted October 15, 2013 Backofenreiniger + Fleiss Einfach nur einlegen bringt nix... Pack den so auf'n Schreibtisch und gut Quote Link to comment Share on other sites More sharing options...
ZiD! Posted October 15, 2013 Report Share Posted October 15, 2013 Backofenreiniger + Fleiss Einfach nur einlegen bringt nix... Pack den so auf'n Schreibtisch und gut Traust mir wohl nich zu oder was^^ Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted October 15, 2013 Report Share Posted October 15, 2013 Öhm................ Quote Link to comment Share on other sites More sharing options...
ZiD! Posted October 15, 2013 Report Share Posted October 15, 2013 Öhm................ Quote Link to comment Share on other sites More sharing options...
till_29 Posted October 15, 2013 Report Share Posted October 15, 2013 geht der husky 610 gaszug durch diese Schlaufe am Rahmen? Quote Link to comment Share on other sites More sharing options...
Ben Posted October 15, 2013 Report Share Posted October 15, 2013 Sollte er ja. Quote Link to comment Share on other sites More sharing options...
till_29 Posted October 15, 2013 Report Share Posted October 15, 2013 super. Danke. mach grad Nachtschicht in der Höhle. Quote Link to comment Share on other sites More sharing options...
Ben Posted October 15, 2013 Report Share Posted October 15, 2013 Haha, viel Spaß! Und Rheuma-auf Quote Link to comment Share on other sites More sharing options...
till_29 Posted October 16, 2013 Report Share Posted October 16, 2013 läuft ich will euch den stalk of the night nicht vorenthalten. 165 bridgestone slicks kosten weniger als 130 euro ???? ist das so normal?? is nicht nur auf einer seite so....kräss. Quote Link to comment Share on other sites More sharing options...
Ben Posted October 16, 2013 Report Share Posted October 16, 2013 Normal is das nich. 149 ist eher Normalkurs denke ich! Quote Link to comment Share on other sites More sharing options...
ZiD! Posted October 16, 2013 Report Share Posted October 16, 2013 mal ne kurze frage, mein lenkerschloss rastet nichtmehr ein. ich kanns nach links drehen und ca3-4mm reindrücken aber dann stockt es.... ich hab jetzt 20 min versucht durch rütteln das reinzubekommen, ich habs mit wd40 geflutet aber nix hilft... irgendjemand ne idee??? Quote Link to comment Share on other sites More sharing options...
Ben Posted October 16, 2013 Report Share Posted October 16, 2013 Ja, fahr nur noch auf der Strecke. Dann hast du das Problem nicht. Quote Link to comment Share on other sites More sharing options...
till_29 Posted October 16, 2013 Report Share Posted October 16, 2013 es gibt tatsächlich jemanden der das benutzt. krass. ziehen lassen weiter versuchen. musste ich mal bei dem moped von meinem vater wegen tüv machen. die haben gemeckert das es nicht ging - ich wusste gar nicht von der existenz. dauerte 2 std. rütteln, klopfen, einziehen lassen. tapfer bleiben. ansonsten siehe oben. Quote Link to comment Share on other sites More sharing options...
ZiD! Posted October 16, 2013 Report Share Posted October 16, 2013 man das scheiß ding is neu! keine 4 monate alt^^ habs bei der inspektion aufbohren und neu einsetzen lassen Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted October 17, 2013 Report Share Posted October 17, 2013 Wieviele linke Hände hast du eigendlich ? ^^ Glaub der lenker darf nicht gaaaanz nach links eingeschlagen sein. Quote Link to comment Share on other sites More sharing options...
ZiD! Posted October 17, 2013 Report Share Posted October 17, 2013 (edited) Wieviele linke Hände hast du eigendlich ? ^^Glaub der lenker darf nicht gaaaanz nach links eingeschlagen sein. Willst du mich verarschen? Ich habe den Lenker von Anschlag bis Anschlag gedreht und probiert! Oder meinste ich steh daneben und drück eine stunde den schlüssel da rein??? Ich merke ja wie der stift in die Öffnung geht, aber eben nich komplett.... Tante EDIT: Thomas dir werd ichs zeigen, ich werde die kaputte blinkergühbirne SELBER wechseln *muhahhaaaaa* Edited October 17, 2013 by ZiD! Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted October 17, 2013 Report Share Posted October 17, 2013 Siehste.... Dummblapp ! Bei anschlag rechts kommste mit deinen Patschen gar nicht an das Lenkerschloss dran Also Anschlag bis Anschlag geht technisch gar nicht Quote Link to comment Share on other sites More sharing options...
ZiD! Posted October 17, 2013 Report Share Posted October 17, 2013 wenn du den lenker langsam von anschlag links nach anschlag rechts bewegst kommst du in die stellung wo's durchpasst.....es hakt auch ein wenig ein aber ich kriegs nich 100% rein und den schlüssel somit wieder raus.... Quote Link to comment Share on other sites More sharing options...
ZiD! Posted October 18, 2013 Report Share Posted October 18, 2013 es gibt tatsächlich jemanden der das benutzt. krass.ziehen lassen weiter versuchen. musste ich mal bei dem moped von meinem vater wegen tüv machen. die haben gemeckert das es nicht ging - ich wusste gar nicht von der existenz. dauerte 2 std. rütteln, klopfen, einziehen lassen. tapfer bleiben. ansonsten siehe oben. So geht immernoch nich! Das schloss lässt sich ultraleicht drehen und auch reinschieben (ca 2/3) dann gehts nich weiter und ich kann auch nich weiter drehen..... Werd damit morgen auf arbeit fahren und das mal von unseren werkstattpeoples checken lassen ggf. morgen nachmittag selber mal bissl basteln *grummel* Quote Link to comment Share on other sites More sharing options...
Bastel Posted October 18, 2013 Author Report Share Posted October 18, 2013 ... hat bestimmt der Thomas kaputt gemacht, Unfall oder so. Lenkrohr ist bestimmt verbogen Gruß Bastel Quote Link to comment Share on other sites More sharing options...
ZiD! Posted October 18, 2013 Report Share Posted October 18, 2013 Neee da muss ich den ma in schutz nehmen! der macht bestimmt viel blödsinn aber hier trift ihn denk ich mal keine schuld ^^ denn an dem abend wo ichs das erste mal gepostet hab gings ja noch.....nur eben 2 stunden später nichmehr -.- (warum auch immer) Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted October 18, 2013 Report Share Posted October 18, 2013 ... hat bestimmt der Thomas kaputt gemacht, Unfall oder so. Lenkrohr ist bestimmt verbogen Gruß Bastel WENN ich mist baue... Hab ich schon immer offen dazu gestanden. Bei sowas bin ich vedammt ehrhaft. Lieber komm ich selber für Schaden auf als meinen Ruf zu bekleckern... Aufrechten Hauptes läuft sichs immernoch am besten... Da könnten sich ruhig einige Leute ein paar Scheiben von mir abschneiden PS. Bin bis übermorgen in Münster... Gibts hier was was man unbedingt gesehen haben muss wenn man die Frau im Kinderlan... Ähm...räusper...hust... Schuhladen abgegeben hat ? Quote Link to comment Share on other sites More sharing options...
Bastel Posted October 19, 2013 Author Report Share Posted October 19, 2013 (edited) ... war nur Spaß um den ZID! ein wenig durcheinander zu bringen, den alten Fopper Sorry wenn du dich angegriffen gefühlt hast, hatte extra einen Smily dahinter gemacht weil Spaß. Ist aber goldig wie der Steffen dich gleich verteidigt hat Ich fahr nur ungern mit fremden Fahrzeugen, fühl mich dabei nie wohl. Was gibt es denn so schönes in Münster, ich wissen will Dann muß der ZID, nachdem er schon seinen Motor kaputt gefahren hat, auch noch sein Lenkrohr auf dem gewissen haben. Wohl wie früher mit dem Roller zu dicht auf ein Auto aufgefahren und dann mit ordentlich Bums ins Heck geknallt Ist der Lenker noch i.O. Gruß Bastel Edited October 19, 2013 by Bastel Quote Link to comment Share on other sites More sharing options...
Ben Posted October 19, 2013 Report Share Posted October 19, 2013 Münster hat nen ganz schönen Schlosspark und die Kneipenszene dort ist ziemlich lebhaft wegen der vielen Studenten. Fährste via Hannover? Wenn ja ruf eben an aufn Käff. Quote Link to comment Share on other sites More sharing options...
