kab-pro Posted December 21, 2014 Report Share Posted December 21, 2014 For sale minor hour project bike. The reason why it goes for market is very common - no time to use it, and building gave more fun like riding. Bike has only 500 km after project has been finished. Engine got new bearings, conrod, piston, cylinder, seals, valves, valve guides and camshaft. All other mods are visible on to the pictures. All plastics included tank and seat are new as well as lights. Price 4500 Eur. Pictures speaks itself. Recap of the mods. Engine: 600 cm3 at stock bore (98 mm) Stroke (79.4 mm) & lightweight crank (~ -450 gr) SKF high speed crankshaft bearings T-6 Wossner High comp piston size (98 mm) Valves IN D 37 mm EX D 33 mm Tin-Bronze valve guides SMS610E racing camshaft Ported head Ignittion: PMC racing CDI Brisk 3D spark plug Intake: FlowPro Keihin FCR MX 41,5 mm R&D power pump R&D ims remote control HTM-Racing air filter FlowPro custom made fuel and coolant catch can Samco racing vent lines Exhaust: Semi custom ss header + aluminum canister Suspension Front: New Marzochi-supermoto 45mm Rear: Zachs SMR450 Chasiss: FlowPro custom made frame guard Brake: Front: OEM floating disc D¸ 320 mm. Brembo radial 4piston caliper. Brembo racing radial master cylinder Controls: Brembo hydraulic clutch mastercylinder Magura hudraulic clutch cylinder + line. Nook fat bar WRP fat bar clamps Zeta hand guards Pro-Stompa series foot pegs Electric: Front light (511 husqy 2012) Rear light LED (Yamaha WRF) with FlowPro custom made frame Led turning indicators with resistors Coso computer FlowPro custom made computer pad. Quote Link to comment Share on other sites More sharing options...
