El_CaminoLV Posted June 18, 2014 Report Share Posted June 18, 2014 Hi Guys! I'm making these adapters for TM MX and EN to Supermoto conversion (Marzocchi USD, KYB and Ohlins fork) Just let me know if you need one 1 1 Quote Link to comment Share on other sites More sharing options...
Throttle_Jockey Posted June 18, 2014 Report Share Posted June 18, 2014 Hey Mate, I've already seen those on Spy...ehm, Facebook - nice work! From where do you ship your stuff? ...just for shipping €€€ questions... Are those for 305, 310 or 320mm disks? With some distances between caliper and adapter it should fit to all, right? What for hubs do you use with your adapter? MX/EN or smr hubs? Quote Link to comment Share on other sites More sharing options...
Ben Posted June 18, 2014 Report Share Posted June 18, 2014 Aleks, can you make one for a 2002 Honda? 310mm disc? Showa forks. What is the bolt spacing on the fork leg? Also what is the spacing for the radial caliper - 100 or 108mm? Quote Link to comment Share on other sites More sharing options...
El_CaminoLV Posted June 18, 2014 Author Report Share Posted June 18, 2014 I'm from Latvia, I'm asking 80eur for them, including shipping. They are for 100mm calipers. The adapters were made for 305mm disc, but they work well on 310, because the difference in radius is just 2,5mm, for 320 you will need spacers, but can make those, no problem. On this TM MX450Fi 2012 we used KTM wheels with TM spacers. I'm working on adapter for other models, just need to get my hands on a bike to measure everything and test fitt, I'm working on it Quote Link to comment Share on other sites More sharing options...
Ben Posted June 18, 2014 Report Share Posted June 18, 2014 What measurements do you need? Maybe I can assist you. Quote Link to comment Share on other sites More sharing options...
El_CaminoLV Posted June 18, 2014 Author Report Share Posted June 18, 2014 I will get my hands on a RMZ with Showa tonight Should be able to work out on that Quote Link to comment Share on other sites More sharing options...
El_CaminoLV Posted June 18, 2014 Author Report Share Posted June 18, 2014 Benjamin! If you could post a pic of your fork bottom. Modified the bracket to fit Showa, will test it tomorrow on RMZ, will keep you updated! Quote Link to comment Share on other sites More sharing options...
Ben Posted June 18, 2014 Report Share Posted June 18, 2014 Quote Link to comment Share on other sites More sharing options...
El_CaminoLV Posted June 19, 2014 Author Report Share Posted June 19, 2014 Here it is fitted on Showa Used some shims to space out, I will make spacers (9mm needed) + 70mm bolts for Magura/Beringer/Brembo (4mm for 310disc) Quote Link to comment Share on other sites More sharing options...
trumidor Posted April 11, 2016 Report Share Posted April 11, 2016 Hey I need this adapter for brembo caliper , motocycle TM rancing en 300 2t 2010 year marzochi front Adrian Quote Link to comment Share on other sites More sharing options...
Phil36 Posted May 10, 2017 Report Share Posted May 10, 2017 (edited) Hello, what would an adapter for a TM 450 2012 (MX-EN) with Mazocci fork cost? For a 320 brake disc. Edited May 10, 2017 by Phil36 Quote Link to comment Share on other sites More sharing options...
Adam Kopec Posted October 31, 2019 Report Share Posted October 31, 2019 hi do you make this adapter for ktm 660 smc 2004?thanks Quote Link to comment Share on other sites More sharing options...
mat_rock667 Posted April 11, 2021 Report Share Posted April 11, 2021 Hi, are you still making these brackets? need one for a kTM 990 adventure. Original forks. able to make one? Quote Link to comment Share on other sites More sharing options...
mat_rock667 Posted April 11, 2021 Report Share Posted April 11, 2021 2 minutes ago, mat_rock667 said: Hi, are you still making these brackets? need one for a kTM 990 adventure. Original forks. able to make one? On 6/18/2014 at 7:14 PM, El_CaminoLV said: Hi Guys! I'm making these adapters for TM MX and EN to Supermoto conversion (Marzocchi USD, KYB and Ohlins fork) Just let me know if you need one Still making these? need one. Quote Link to comment Share on other sites More sharing options...
