Guest Connader Posted July 29, 2014 Report Share Posted July 29, 2014 Sorry for that I will try to include an english translation the next time I post in Latvian. Last Night I thought it was because I was drunk, but this morning still??? Quote Link to comment Share on other sites More sharing options...
El_CaminoLV Posted July 29, 2014 Report Share Posted July 29, 2014 (edited) OK, so what is the problem with clutch? I just installed mine and => GO! Edited July 29, 2014 by El_CaminoLV Quote Link to comment Share on other sites More sharing options...
kab-pro Posted July 29, 2014 Author Report Share Posted July 29, 2014 es zinu You are absolutely right DOC Quote Link to comment Share on other sites More sharing options...
kab-pro Posted July 29, 2014 Author Report Share Posted July 29, 2014 Elcamino_LV: The problem is simple, everything fits and works just fine, but after a couple of runs it is clear that the clutch lacks travel (stroke). I measured it with vernier (bīdmērs) and it seems to be 1.2mm no matter how much I adjust the freeplay between pressure plate and the pressure bearing, my guess - that is way too low. Any ideas about your clutch travel? At this point I cannot get the clutch to grip at WOT and to be able to actually disengage it. It is either one or the other. Right now I am hoping that a new actuator pullarm will cure this problem because it is obvious that it has sustained quite a lot of wear. What do you think? A moška vajag arī pa latviski? (slang - maybe I need to include Latvian translation?) Quote Link to comment Share on other sites More sharing options...
El_CaminoLV Posted July 29, 2014 Report Share Posted July 29, 2014 (edited) So the clutch travel is 1,2mm? What lever are you using? I adjusted my ASV to be quite far from bars to allow max travel, but nevertheless, Adige needs quite small travel. I could check my clutch tomorrow, or lend you my clutch lever, it is from crf. Did you assemble the clutch pack correctly? Do you have the required min/max thickness? Edited July 29, 2014 by El_CaminoLV Quote Link to comment Share on other sites More sharing options...
kab-pro Posted July 30, 2014 Author Report Share Posted July 30, 2014 The clutch is brand new, so the thicknesses should be correct. And I assembled the clutch following the manual they provided. It can be disengaged fully and it can grip fully, just not both at the same time. It could be really nice if you could measure the travel your clutch makes while fully pressing the lever. I hope it's more than 1.2mm. Also what oil are you using? Quote Link to comment Share on other sites More sharing options...
El_CaminoLV Posted July 31, 2014 Report Share Posted July 31, 2014 Ok, I'll try to do that today. I'm was using bellray gear saver 80W, but now filled motorex 10w60 I have separate oiling systems for engine and gearbox Quote Link to comment Share on other sites More sharing options...
kab-pro Posted August 10, 2014 Author Report Share Posted August 10, 2014 Today was the first track day, have to admit, it was my first sumo track day as well. Heres a good picture of the track itself, location - very close to home (about 5km straight) This is one of those tracks that stood as far back as the soviet times in here. http://rullitis.lv/?project=sporta-un-atputas-kompleks-rullitis/ [video=youtube;R00EYKS85Ro] Did a total of 4 sessions, each 6 - 7 laps long. Back home after an exhausting day in a Vanucci oven. Quote Link to comment Share on other sites More sharing options...
Ben Posted August 10, 2014 Report Share Posted August 10, 2014 So, how did you like it? Quote Link to comment Share on other sites More sharing options...
kab-pro Posted August 10, 2014 Author Report Share Posted August 10, 2014 How did you like our track? I actually liked it pretty much, the bike felt like a properly tamed beast, plenty of power, easy to handle. Tires were like glued to the ground, and the Beringer was outstanding! Didn't try to change the triple clamp settings though. Still fighting the clutch issue! Quote Link to comment Share on other sites More sharing options...
kab-pro Posted September 1, 2014 Author Report Share Posted September 1, 2014 Yeeehhhaaa !!!!!........ Last Saturday was perfect practice day. Rode 5 sessions, totally about 90 laps. My ass is sore [video=youtube;sYzc3b-bhTI] Quote Link to comment Share on other sites More sharing options...
Ben Posted September 1, 2014 Report Share Posted September 1, 2014 Looking good Karlis! Also lol@2:52 Quote Link to comment Share on other sites More sharing options...
kab-pro Posted September 2, 2014 Author Report Share Posted September 2, 2014 Other view. [video=youtube;JEFK9qXwlWQ] Quote Link to comment Share on other sites More sharing options...
Guest Connader Posted September 2, 2014 Report Share Posted September 2, 2014 Awesome!!! How did you fixed your Clutch-Issue?? Quote Link to comment Share on other sites More sharing options...
kab-pro Posted September 2, 2014 Author Report Share Posted September 2, 2014 Awesome!!! How did you fixed your Clutch-Issue?? do you want to laugh now?? At the final was enough to enlarge the stroke of the hand leaver :mhihi: I do not know where I was looking before Quote Link to comment Share on other sites More sharing options...
Ben Posted September 2, 2014 Report Share Posted September 2, 2014 Quote Link to comment Share on other sites More sharing options...
Guest Connader Posted September 2, 2014 Report Share Posted September 2, 2014 Well.....shit happens!! Quote Link to comment Share on other sites More sharing options...
kab-pro Posted September 2, 2014 Author Report Share Posted September 2, 2014 Quote Link to comment Share on other sites More sharing options...
Ben Posted September 2, 2014 Report Share Posted September 2, 2014 Nice bike man... nice bike. Minus the colored blingy bits Quote Link to comment Share on other sites More sharing options...
Guest Connader Posted September 2, 2014 Report Share Posted September 2, 2014 Definitely!! Want one!!!! Quote Link to comment Share on other sites More sharing options...
kab-pro Posted September 7, 2014 Author Report Share Posted September 7, 2014 Quote Link to comment Share on other sites More sharing options...
Guest Connader Posted September 7, 2014 Report Share Posted September 7, 2014 Nice, but who are you?? The little Man all right??? Quote Link to comment Share on other sites More sharing options...
kab-pro Posted September 7, 2014 Author Report Share Posted September 7, 2014 Look in the middle! Quote Link to comment Share on other sites More sharing options...
Guest Connader Posted September 7, 2014 Report Share Posted September 7, 2014 I know, just wanted to bug you!! Congrats!!! So, that means I'm going to take Top Step also soon?? Nice.... Quote Link to comment Share on other sites More sharing options...
Ben Posted September 7, 2014 Report Share Posted September 7, 2014 Hammer! Glückwunsch! Quote Link to comment Share on other sites More sharing options...
