Throttle_Jockey Posted January 29, 2017 Report Share Posted January 29, 2017 Ne, das ist ne ATR 72KLICK Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted January 29, 2017 Report Share Posted January 29, 2017 Und was ist mit Jutta ? Quote Link to comment Share on other sites More sharing options...
Ben Posted January 29, 2017 Author Report Share Posted January 29, 2017 Gibt noch nix Neues, warte auf das Rad. Quote Link to comment Share on other sites More sharing options...
Bastel Posted February 7, 2017 Report Share Posted February 7, 2017 https://www.ebay-kleinanzeigen.de/s-anzeige/ktm-husqvarna-husaberg-oehlins-gabel/597307071-306-4989 Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted February 7, 2017 Report Share Posted February 7, 2017 Quote Link to comment Share on other sites More sharing options...
Ben Posted February 7, 2017 Author Report Share Posted February 7, 2017 Oh! Zum Glück Pepe getuned, da schwindet das Interesse schnell 1 Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted February 14, 2017 Report Share Posted February 14, 2017 Noch nicht mal fertig und schon geadelt... tztztz... 1 Quote Link to comment Share on other sites More sharing options...
Zerolution Posted February 14, 2017 Report Share Posted February 14, 2017 Vllt fehlt da blos ein leerzeichen.Jutta weg? 1 Quote Link to comment Share on other sites More sharing options...
Throttle_Jockey Posted February 14, 2017 Report Share Posted February 14, 2017 Die Juttäische Volksfront braucht noch nen wenig Zeit...soweit ich weiß. 2 Quote Link to comment Share on other sites More sharing options...
Ben Posted February 14, 2017 Author Report Share Posted February 14, 2017 Juttäische Volksfront, pah. Das ist die Volksfront von Juttäa! 1 Quote Link to comment Share on other sites More sharing options...
Brösel#33 Posted February 15, 2017 Report Share Posted February 15, 2017 Quote Link to comment Share on other sites More sharing options...
Ben Posted February 18, 2017 Author Report Share Posted February 18, 2017 Bei frühlingshaftem Wetter hatte ich heute ein bisschen Zeit, um mal ein Paketchen auszupacken, welches diese Woche schon kam. Oh lala, einö seschzehnzöllfelgö gleisch gepaart mit eine Reifön vonne dö Mischelöööö! Die 16" ging genau so leicht zu montieren wie das 16.5er Pendant. Ein Hoch auf weiches Franzosengummi! Der Schlauch kam von Metzeler, ganz dolle prima. Dann musste ich in Absenz meiner Gabelbrücke, die zum vermessen beim Nik hausiert, das ganze Frontend meines Crossers auseinander rupfen. Hrmpf! Gerade komplett mit neu gestopftem Auspuff, nun muss sie leiden. Is ja fürn guten Zweck. Der Hintergrund ist, dass ich mich irgendwie für ein Offset bei den neuen Gabebrücken entscheiden muss. Ich tendiere zu 16mm, aber messen macht ja klug. So montierte ich also alles provisorisch und überlegte mir, wie ich wohl am schlausten den Radstand messen könnte... Das kam dabei heraus. Als Messinstrument hielt ich einen Gegenstand im Lot an beide Achsen und markierte die Achsmitten vorne und hinten. Die Stellschraube hinten ist ziemlich weit rausgedreht, also gerade recht langer Radstand im Verhältnis zum Möglichen. Messen muss ich morgen, hatte keinen Zollstock zur Hand. Ist aber noch ein gutes Stück Arbeit, bis das alles passt. U.a. müssen noch Hülsen für die Achse her (24mm Lager, 20mm Achse, Brückenbreite wird +10mm), dann ein Bremssatteladapter axial auf Radial für 305er Scheibe, Motor wieder zusammen stecken (Dichtsatz ist schon da) und sicherlich noch Kleinscheiss. Einiges lasse ich für nach dem Rollout übrig. Will keine Lager in Umlenkung etc. tauschen jetzt, das wird neu geschmiert und dann erst getestet. 3 Quote Link to comment Share on other sites More sharing options...
Ben Posted February 19, 2017 Author Report Share Posted February 19, 2017 Für mich als Notiz: Radstand 1500mm (Achse fast ganz hinten) Schwingenachse zu Achsloch hinten 55-60 (SMX) Schwingenachse zu Achsloch hinten 58-63 (MX) Achsversatz 36mm Lenkwinkel 26° Offset Brücken MX 22mm 1 Quote Link to comment Share on other sites More sharing options...
Ben Posted March 4, 2017 Author Report Share Posted March 4, 2017 Va bene ragazzi, es ging ein bisschen weiter. Für die ordentliche Montage des 300er Zylinders habe ich einen Ringschlüssel geopfert. Erst gefeilt, war scheisse, dann gedremelt, ging besser, am Ende mit der Flex und Schrubbscheibe. 1a Passform nu. So konnte ich den Zylinder gut montieren und alle Muttis anziehen. Die Quetschkante mit der dicksten 0,6mm starken Dichtung beträgt 1,35mm. Das habe ich dann prompt so gelassen. Die beiden weiteren Optionen im Dichtkit wären gewesen 0,5 und 0,4mm. Da ich vom Raabschen Andre noch neue Schrauben für die Bremsscheibe bekommen hatte, hab ich diese montiert. Die Umlenkung wollte ich ja auch immer noch mal inspizieren. 2/3 Lager waren noch halbwegs brauchbar: 1/3 war unterirdisch: Habs nun wieder gängig gemacht und fein gefettet. Wenn sich alles bewährt hat, dann muss der Knochen mal revidiert werden. Habe dann noch das 14er SMX Ritzel montieren wollen, das passt aber nicht, da es am Schwingenschleifer ansteht. Einzige Option: 13er. Passt gerade so: Hab dann noch n bisschen Kleintüddel getrieben. Neue BR8EG Kerze rein, Airbox in den Heckrahmen montiert, das wars dann aber auch schon. Das Warten auf die Brücken ist unerlässlich, bis die Front wieder zusammen kann. Vorher kann ich auch mit dem Vorderrad und den benötigten Distanzen nix machen, ebenso wegen des Bremszangenadapters. Ich werde deswegen beim nächsten Mal die Kühler wieder montieren, das Plastik vom Kleberzeugs befreien und alles soweit zusammen stecken, wie es eben geht. Der Kickstarter steht noch komisch montiert am Rahmen an, 1 Zahn zu weit hinten. Ich denke mal, da war entweder die Birne verzogen und er lag dort an, oder der Anschlag ist verschlissen wie bei meiner 125er zuvor. Die Kette will noch abgelängt und montiert werden, dann siehts schon mal wieder viel mehr nach Moped aus. 3 Quote Link to comment Share on other sites More sharing options...
Brösel#33 Posted March 5, 2017 Report Share Posted March 5, 2017 cool warum lässt dir nicht ne brücke fräsen wo du den versatz im eingebauten zustand verstellen kannst? so eine kommt jetzt an eine KTM Andre hat die auch beim fuhrbach verwendet Quote Link to comment Share on other sites More sharing options...
Guest Connader Posted March 5, 2017 Report Share Posted March 5, 2017 vor 36 Minuten schrieb Brösel#33: Andre hat die auch beim fuhrbach verwendet Auch bei vielen anderen TM'lern in der IDM. Hat mich auch immer gewundert wie die originalen 16mm DInger bei den alten MX und Factoryrahmen funzen sollen (da ist doch min. 1° LW-Unterschied!?)!? Guido: Kennst Du da eine Anlaufadresse für so eine Einzelanfertigung? Quote Link to comment Share on other sites More sharing options...
Brösel#33 Posted March 5, 2017 Report Share Posted March 5, 2017 na klar dali ;-) ich weiß wer sie gefräst hat.... Quote Link to comment Share on other sites More sharing options...
Guest Connader Posted March 5, 2017 Report Share Posted March 5, 2017 Guido.....ich sag's immer wieder: Du bist mein Held!!! Jetzt noch den Plotter anschmeissen und Du bist quasi "Mr.Perfekto"!! Sry. für den Fredklau, Schuster!! Weitermachen!! Quote Link to comment Share on other sites More sharing options...
Ben Posted March 5, 2017 Author Report Share Posted March 5, 2017 Jo ich weiß, dass es die gibt. Aber Nik wollte so eine nicht machen. Und der, der die für Andre gemacht hat... naja vielleicht habt ihr zeitlich mehr Fortune als andere Menschen Quote Link to comment Share on other sites More sharing options...
Guest Connader Posted March 5, 2017 Report Share Posted March 5, 2017 vor 39 Minuten schrieb Ben: naja vielleicht habt ihr zeitlich mehr Fortune als andere Menschen Heisst? Halbes Jahr drauf warten?? Quote Link to comment Share on other sites More sharing options...
Ben Posted March 5, 2017 Author Report Share Posted March 5, 2017 Kanns dir auch nur aus 2. Hand berichten, wie du weißt muss das nicht immer allgemeingültig sein... Nach der Story hatte ich aber ad hoc keinen Bock auf sowas. Quote Link to comment Share on other sites More sharing options...
MaK Posted March 5, 2017 Report Share Posted March 5, 2017 Gut (Brücken-) Ding in welchem Präzision und Hingabe des besagten Erbauers steckt will halt Weile haben. Zudem macht der das ja alles nebenbei, von daher immer easy. Quote Link to comment Share on other sites More sharing options...
Brösel#33 Posted March 5, 2017 Report Share Posted March 5, 2017 vor 8 Stunden schrieb Connader: Heisst? Halbes Jahr drauf warten?? sagst bescheid und in vier wochen dürfte dem evtl fertig sein... Quote Link to comment Share on other sites More sharing options...
dr.-hasenbein Posted April 1, 2017 Report Share Posted April 1, 2017 Jutta ? Quote Link to comment Share on other sites More sharing options...
Ben Posted April 1, 2017 Author Report Share Posted April 1, 2017 JUTTAAAAAAAA....! Quote Link to comment Share on other sites More sharing options...
